vin #help???
- cooltoolguy
vin #help???
ok, have truck home now, the 1972 ford dump body, what trip.. the wiring has the nutter bypass in the cab and the upper column bearing is missing hehe , it was a 2 hander all the way home
(is the steering wheel supposed to upside down when going straight i thinks it needs an alignment) any way the question i have is... the vin# is F37YEP60***, after looking I am still confused about the F37 when the truck is an F350. I am sorry for being a schlep, but Fords are new to me. thanks in advance, steve
- ToughOldFord
re: vin #help???
http://www.fordification.com/data-1972.htm
It shows F35 for the 350, I'm going to guess that F37 means one ton dually.
- 4x4x4crewcab
re: vin #help???
F37 No mention of this in the 64-72 book? Only F35 =64 up F350
I did find mention of the F37 in the 73 to 79 book showing that it references to a chassis and cab F350. So you may have a mid to late 72 with a bit of the 73 technology
Mark
1970 Ford F-250 Crew Cab 4x4 short box
1969 Volkswagen Karmann Ghia
1999 Ford Windstar
1983 Chevrolet Silverado p/u
1990 Lincoln Town Car
1998 Lincoln Town Car
Does your truck need emblems? Check out http://www.onceuponapart.com
1999 Ford Windstar
- 72hiboy4x4
F-370 6,600
F-371 8,000
F-372 8,300
F-373 9,000
F-374 10,000
F-375* 10,000
F-376* 9,000
as per Keith's vin data page here....
FYI: my F250 4x4 has a starting Vin of F-26xxxxx. its a way to ID the chassis model
F-371 8,000
F-372 8,300
F-373 9,000
F-374 10,000
F-375* 10,000
F-376* 9,000
- ToughOldFord
re: vin #help???
Okay, I didn't originally scroll down far enough.
Learn something new everyday, I had thought all one tons, (duallys), were rated at 10,000.
- cooltoolguy
re: vin #help???
ok I finally found the vin tag under 30 layers of paint here it is,
135" WB, used to be rangoon red with black vinyl interior, F374, NP435 trans with PTO, Dana 70 rear with 4:10, Chassis cab built in mahwah NJ JUL 1972, GVW 10,000 with a 360. whew!!
now where do I find doors?
steve
72 Ford F-350, 2WD, 4 speed 360, Dump truck
76 Ford F-350, 2WD, Cab and Chassis <--gone
re: vin #help???
The doors from any '68-'72 F100-F350 doors will work just fine. (The '67 doors will bolt on correctly, but have a different style of interior door release handle, and there's no lock button.)
