Another update of my front clip.
On these pics I notched the frame rails because I will use bigger air bags wich will give me a smoother ride plus more lift. The upper control arm mounts are done and will be welded in once I build the upper control arms, also the bag mount's will be done before the end of the week. After that's done the front clip can be welded to the rear frame and then come the cab mount's,motor mount's trans mount and so on and so on. Next update I will have pics of the frame welded together with the cab mounts in place and all the air ride done. This is how I feel right now:hd: Asta luego. Later
Almost done
- marz68
- marz68
- marz68
- 460 crew
re: Almost done
Looks like alot of work, it almost made me tired lookin at the pics. When your done that'll be one nice piece to be proud of
- Heavenlyfire
- boots
re: Almost done
awesome!!! What kindof welder?
P.S- Get some saftey glasses man!!!!
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- 1970F250
- marz68
