71 f-250 mustang II Suspension
Looking for a kit for my truck. does any one know how to get it or do i take it off of an actual mustang II???
71 f-250 2wd future low rider. going with a 383 stoker. 1969 351w block.
- customcrewcab
re: 71 f-250 mustang II Suspension
fatmans is the only place that sells a cross memeber that i know of. its the on thats 60 1/2 wide and says 6779 ford pickup those are the years it fits one years only has a dash for some reason. you can get the components from a junk yard but i would get tublur lowers at least so you don't have to run the rods on the bottom.
http://www.fatmanfab.com/06page4.htm
http://www.fordification.com/galleries/ ... ?cat=10106
if theres a new way, i'll be the first in line. it better work this time
1970 crewcab 393w afr heads, 6 speed, turbocharged, 6 piston calipers 13" rotors on all 4 corners
