points setting
points setting
do you know the gap for 390 points, im gonna do it right , the matchbook cover thing aint right, im gonna buy a gauge, thanks
- heep70
Re: points setting
It has been awhile but I think it is .017.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- stephen44
Re: points setting
Point gap---.017
Plug gap----.034
Dwell Angle-26-31
Timing------10-12 BTDC
thanks
Stephen
(1967 F100, FE352, 2wd, 3 on the tree, flareside)
Stephen
Re: points setting
cool thanks . the matchbook thing is poor mans way, i got a feeler gauge thanks
- 70_F100
Re: points setting
Feeler gauge probably won't get it much closer than a matchbook.
You need to get a dwell meter to set them right.
That's not an oil leak
Re: points setting
i have a set of feeler gauges in my glvoe box. i also have a bok of mathces just incase i need to smoke? or the gauges have rusted up again and i need to buy another set.
Re: points setting
distributor move a tiny bit,point open and close a little, this normal. enought to open and close it a little.fordman wrote:i have a set of feeler gauges in my glvoe box. i also have a bok of mathces just incase i need to smoke? or the gauges have rusted up again and i need to buy another set.
Re: points setting
when setting the points the dist shouldnt move. it could if you bump it some how. but if the center shaft moves some it could still be good enough to run. if it moves alot then the bushing are worn and need done something with.
