fe tapping need advice
Jarred Hodges
Post by Jarred Hodges »
I finally got the electric fuel pump hooked up on my truck. I went to drive it and heard a tap at about 2500 rpm. It hols good oil pressure and does not tap until about 2500 rpm. My dad told me it might be a loose rocker arm. I checked and all were torqued to 45lb. I am thinking possibly a bad lifter. It does not sound like a rod knock. Anybody else have any ideas
1971 F-100 swb 401 fe , edelbrock intake, cam, valve covers, longtube headers with twin 2.5 inch exhaust, aluminum wheels.
1965 Mustang 350 glide 7.45 at 90mph
1972 maverick 460 swap in progress
2002 z28 a few bolt ons
Re: fe tapping need advice
Did you take out or disable the old fuel pump ?
Jarred Hodges
I took the old fuel pump off and installed a block off plate
check to see if the pushrods will move up and down without trying very hard. to see if they are loose inside of the rockers or the lifter. maybe they are worn down some.
