460 Swap Questions
BobbyFord
460 Swap Questions
Post by BobbyFord »
What oil pans have you guys used? I'm going to go with a rear sump. I know the 460 Econoline pans work. There are rear sump pans available from Ford Racing parts (like the Fox body swap pans), but there is also a M-6675-T460 racing pan in the catalog that looks more like what I want. I've got the finished engine (about 550HP :D) sitting on the floor in the garage and it has the stock front sump pan on it. I still need to get a few more parts together before doing the swap.
71f100anddodgemagnum
Re: 460 Swap Questions
Post by 71f100anddodgemagnum »
wow i was thinking of doing a set up about like this, i pland on using a 514 or 521 bore and doing about 600 to 700 but we will see , what trans do you plan on using....
1971 f-100 sport custom two wheel drive with 360 auto, restoration
2005 dodge magnum 5.7 hemi all bolt ons and 100 shot of nitrous
400 rwhp on 100 shot
466 rwtq on 100 shot
BobbyFord
Post by BobbyFord »
I have a C6 out of a early 70's passenger car. I'm going to swap the tailshaft, housing and flange out of my existing FE C6, when I rebuild it.
OldRedFord
Post by OldRedFord »
I too wonder about oil pans. I would like to run a rear sump from a truck. I too have a front sump right now but I do not like the idea of dumping oil all over the cross member.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
