68 Cooling Problems
68 Cooling Problems
I have a 1968 with a 6 cylinder and 3 on the tree in it. For some reason it keeps overheating on me. I have replaced the thermostat on it, but it still seems to overheat going up hills. It came from sea level where it had no problems. I now live at 8500 feet in Colorado. Could it need a new radiator or a water pump? I can't pin point where the antifreeze is coming from when it does overheat, but it doesn't take much for it to boil over. After replacing the thermostat it seemed to be doing much better, but it blew out on me coming back up to my house. Any ideas on where to start?
- AlleyCat
Re: 68 Cooling Problems
Clay
72 F100 4x2 Custom,289, C4 " Slow Ride "
70 F250 4x2 Ranger XLT , 360, C6 "B52 - IV"
96 F150 4x2 XL, 300, E4OD, daily driver
" Professional Wrecker Operators - We Pull for America "
- hotrodfeguy
Just another idea I put a shroud on my truck from a dentside. Never had any problems since. But i like to run alot of time in the old FE.
1972 F-250 4X4 390
1999 F-350 7.3 PS 4X4
1996 Ford ranger 3.0
- FreakysFords
With the change in elevation, I have 2 suggestions.
Check the base timing AND that it's advancing correctly.
Check the fan clutch that it's actually fully engaged when engine hot.
Beyond those two, if uncertain of the cooling system's condition, I'd likely flush the system.
Hope this helps
Frank
Hope this helps
Frank
- willowbilly3
Also don't forget to check the timing.
In additon to timing, check the mixture as well, for that change in altitude you may even have to re-jet the carb...
well, yea the timing and mix can make it run hotter, but usually there is plenty
enough cooling overhead to handle those types of changes.
I think this guy needs a radiator the same as the other one I just
posted to.
Usually a normal cooling system has enough reserve capacity to
handle timing changes, etc. And I'm betting his timing is fairly
normal.. Wouldn't run too well if it was too far off.
Sounds like radiator time to me.. A common problem on many
of these old trucks as many have old half shot radiators.
posted to.
1968 F-250 / 300 six / T-18
Dana 60 - 4.10 Limited Slip
