Foot Feed linkage
- Merlin68F100
Foot Feed linkage
While checking my auto trans fluid I noticed for the first time the foot feed linkage on my stock 68 360 2barrel w/manual choke. What a Rube Goldberg POS this is. When it does fall apart, and I cannot understad what is holding it together now, what sort of upgrade modifications has been done? I don't need NASCAR certified high voltage fly by wire, but something with positive foot feed back would be nice.
"A point in every direction is the same as no point at all."
The Pointless Man
The Pointless Man
Re: Foot Feed linkage
just a straight rod from the pedal to the carb. they can be had at the parts stores. its got a hook for the pedal on on end and a snap linkage piece ont he other end for th carb. or whihc ever end you need they have them. i have personally never had a problem with the trapeze setups. its all held together with pins.
Ford did away with the trapeze in the dentside era, just using a straight rod from the gas pedal to the carb. They're easy enough to find in the U-Pull-Its.
