How can I get more tourque
Re: How can I get more tourque
More info. What gears/tire size? If it's turning 1800rpm or better, it should pull ok.
Its got 3:55 gears and 15" wheels. I was thinking today would an x pipe do any good?
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
- willowbilly3
We so often forget to check all the basics first. If you have a vacuum gauge on it you can tell a lot from that too. Healthy engines will have 17-22 inches with a steady needle. If the needle dips slowly it is probably carb or float level. If it dips fast or vibrates you probably have a valve problem. Overall low can be poor compression or slow timing. It's hard to tune one that's low.
Another thing I like to check is the slack in the timing chain. If you get the engine on top dead center, pop the distributor cap. I can use my hands but you may need to use a socket and breaker to put on the harmonic balancer. While watching the timing pointer, rock the engine back and forth just until you see the rotor move in both directions and note the number of degrees on the timing pointer. A new chain and gears will often have 2 degrees of slack. Most have 4 or so after a run in. A mid time engine may have 6-8 and anything over that you really can't tune.
