When a piston travels down the cylinder it creates a low pressure, something has to take the space that the piston occupied. Now that a low pressure has been created the atmospheric pressure, 14.7 pounds per square in at sea level, forces air in to low-pressure area.
A low pressure is created in the intake manifold below the carburetor throttle plate from the pistons downward motion of the intake stroke. As the throttle plates are opened the low-pressure rises up into the venturi area of the carburetor.
The low-pressure in the primary venturi area causes the atmospheric pressure that is against the fuel inside the float bowl to push the fuel through the main metering jets, through the emulsion tubes (where metered air and liquid fuel are mixed and the fuel becomes a finely atomized liquid and then flows through the secondary booster venturi (the round booster nozzle that the fuel comes out of).
When the choke plate is closed it raises the area of low pressure even higher in the carburetor and closer to the fuel level of the float bowl causing even more fuel flow to through the main metering system.
The reason so much more fuel is needed when the engine is cold is due to the fact that the fuel does not vaporize as well in the cold and tends to puddle on the bottom of the intake manifold floor and it never reaches the cylinders.
As the engine warms and needs less fuel, the choke slowly opens lowering the low-pressure area and less fuel is delivered.
I’m sure this is as clear as mud.
