Anyone know what color the truck pictured in the Avitar is?
I'd like to paint my rebuild in that color scheme. Thanks for the help.
Cheers,
What color is that Truck in the Avitar?
- Daffy_'69
Cheers,
Doug
'69 F250 CS, 390 Rebuild in Process,
Frame off as well
Doug
Frame off as well
- 390Nut
re: What color is that Truck in the Avitar?
If you are referring to the one at the top of the page, you'll have to be more specific. It's a rotating picture, and changes often. (not sure exactly how often, maybe Keith will chime in)
`69 F100 390 4spd driver
Pipes71 did once say, "bumps and bikes.. what a great combo!"
If you're referring to the picture at the top of the forum page, that's a constantly-changing picture, so you'll have to be more specific. I don't think you're asking about that though, since they're all blue.
So that means you're asking about your own avatar. It's kinda hard to tell, but it appears to be Lunar Green. I'd need to see a larger pic to be sure. What's the paint code on your VIN plate? Compare it to the data on this page to find out what the color is:
http://www.fordification.com/data-1969.htm
- Daffy_'69
Sorry guys, to be more clear... there is an avatar for the Show & Events forum and it has been the same teal looking truck every time I've been here...
That is the color I'm interested in.
Thanks and sorry for the confusion.
Cheers,
Cheers,
Cheers,
Doug
Frame off as well
Doug
Frame off as well
