390 Intake question
Engine Forum Archives
Moderator: Ranchero50
Comet
390 Intake question
Post by Comet »
Does anyone make a dual carb intake set up for the 390?
bryantracing460
re: 390 Intake question
Post by bryantracing460 »
Jeremy
Drive It Like You Stole It.........NO FEAR!
69 F-100 swb 2wd 460 C-6. 86 F-150 super cab 2wd 302 AOD.85 Bronco 4wd 300 AOD.
http://www.myspace.com/bryantracing460
Blue Thunder Makes the intake.
Both DSC and Carls Ford Parts are good sources.
BTW,
DSC runs these as "Buy It Now" on EBAY occasionally with the correct Carbs, linkage, fuel log, and so on. Basically, a complete induction for less than you can put it all together for.
Beware though, the Carbs are about a grand, and regular Holleys do not work right.
If you really want a top end rush, go for a "Tunnel Wedge".
:woohoo:
willowbilly3
Post by willowbilly3 »
Lots of vintage ones out there too, including the ones that came on the R code 427s. Be careful if you buy a used Mickey Thompson, it requires a special longer distributor and is worthless without it.
Comet
Post by Comet »
Cool stuff, thanks.
