duraspark question
- splavin90
duraspark question
so i've got this engine a 81' 302 with a duraspark dizzy in it. i put it in my 69 but i'm unsure how to wire it. i know that i need a igniton module, i know how to connect that, but there is a red and a white wire plug that comes off the ignition module. what do the red and white wires go to
69 F100 81' 302 / 73' fmx
I'd rather go hunting with Dick Cheney than go driving with Kennedy
- 72hiboy4x4
I tried to get you to use the older dizzy I have. this is why I said it would be easier to wire up. only one wire tp hook up.
- 390Nut
`69 F100 390 4spd driver
Pipes71 did once say, "bumps and bikes.. what a great combo!"
All this Duraspark talk got me to looking and on www.partsamerica.com for 39.99 plus 29.99 core I can get a distributor. The module is 29.99 so soon I am on my way.
