inginition cylinder
- cathynkeith
inginition cylinder
how do I pull the ing. cylinder out of the switch?
http://s115.photobucket.com/albums/n292 ... type=local
Life is good...... when nothing is wrong that money can't fix.
1969 f100 flareside
1962 ECONOLINE TRUCK (done)
1975 Nova (almost done)
1969 f100 flareside
- splavin90
- cathynkeith
I have a new inginition key cylinder, I have inginition switch pulled and can not get the cylinder out (part where you put the key)
1969 f100 flareside
1969 f100 flareside
You'll need the key for the old cylinder so that you can turn it. I don't recall what position it needs to be in (whether it's the RUN or START position), but then you insert a thin wire, like a straightened-out paper clip, into the small hole on the face to release the lock. You should then be able to pull the tumbler assembly from the case.
- 68F250
Disconnect the battery first!
Then turn key to accessory and insert the paper clip. Turn it another notch to the left and let go, it will pop out. (I think that's how it goes, been a long time.)
Barry
- cathynkeith
oops, ok thanks keith, bodyshop lost key
I should not have left it in truck. just going to buy new switch. thanks
http://www.pro-formanceunlimited.com/sp ... 0carb.html
1969 f100 flareside
1969 f100 flareside
- cathynkeith
thanks 68
1969 f100 flareside
1969 f100 flareside
Yeah, same here....68F250 wrote:Disconnect the battery first!
- flyboy2610
Can you drill out the lock?
Red Green
you'd better be right.
Red Green
