Calvin,Calvin Gunter wrote:Hey td,what are some of the details of running the sending unit wire?Where did you come through the cab to make the wires go to the rear?I know you probably had to lengthen them,how did you lengthen them?TIA,Calvin
i had a role of wire that matched the stock sending unit wire so i just used a butt connector to join them. look were the in cab fuel line goes in the cab floor, there's a rubber grommet right beside it, i punched a little hole in it to run the wire through and used the butt connector to join onto the end of the existing wire. then tucked it out of the way in the corner of the cab.
here's a pic of the sending wire routed with the fuel line along inside the frame rails.
