68 F250 "special" Camper Special Project
67mann
Re: 68 F250 "special" Camper Special Project
Post by 67mann »
:thup: Nice work Chris but, now after looking through page 1, I understand why you had no problems with the Grant steering wheel :hmm: I think :lol:
Keep up the good work...I'll take this back to my other thread :wink:
cash667
Post by cash667 »
made some progress the last days.
Since the shiftboot ist just bolted through the carpet and I don´t like this look, I made a aluminium frame to cover the outer edges of the boot. Looks way better in my mind:
My girlfriend made some black covers for the original beige sunvisors and they look brandnew with them :thup:
Since there was no rearview mirror when I bougth the truck I had to source a new one. My new windshield had no glued on bracket for the date correct 68 mirror and so I ended up using a universal aftermarket chrome mirror. But I think it looks good so far, maybe a bit to much down, but the mirror arm is fixed on that length. It doesn´t look odd in my mind. Made some little stainless retainers for the visor ends to keep them in place.
I was lucky and found a good trim piece for the front fender which was missing, also for the door. So I got the doors reassembled with new rubber parts and felt kits:
The door to cab seals had to be glued to the frame:
Today I installed the hood back on the truck with all trim and mounted the drivers door. Alignment took a while, but it´s ok for now:
I really like the look of the patina paint combined with polished trim :thup: I´ll try to polish the paint aswell, but very carefully.
The next days I´m going to install the passenger side door to get the cab "waterproof". I need to move the truck to the outside because I need the space in my workshop to get the bed finished.
Hopefully I´m ready for road safety inspection by end of march.. :lol: 8)
Cheers
Chris
1968 Mercury Cougar 302
1968 Ford F250 Camper Special 429
cash667
Post by cash667 »
I´m on the final way with my build 8)
After front and cab was done I continued working on the bed. It was already sand blasted an primed (original outside paint surfaces were not blasted and remain).
I started on the underside with some underbody coating and painted everything:
Then I flipped the bed over and installed it back on the frame. Looks very good and I like the exhaust position:
With the bed on the truck I moved along with the inside of the bed. I used a black 2K bedliner which makes real good looking structure:
The next big part was the tailgate. It was kind of butchered from the PO:
After welding new sheet metal in (see pic´s on previous posts) I started to smooth the metal surface with some light use of bondo to get a good surface for paint:
Filler applied:
Next step was applying the basecolor of my two tone paint setup (pebble beige):
So when this first coat was dry I covered everything which should remain beige to apply the white as the second basecolor:
At the end I applied clear coating to the whole tailgate surface. I really like the look and how it went out. (good enough for a dirty garage paint job :lol: )
The back of the tailgate will be coated with bedliner when the clear coating is finally hardened.
Moving along with the interior aswell, got it finished at this point with radio and glovebox installed. I converted the old radio to an AUX In to use it with my smartphone. Maybe I´m adding bluetooth to it in the future. (I´m doing lots of old radio conversions here in germany 8) )
One last topic on the front end was deleting the hood pin holes from the PO. Welding was no option since the paint would had gone. So I made some cover plates and painted them. Looks not that bad and was an easy fix!
At this point I´m waiting for my wheels to get new tires on and tomorrow I´ll get my rear bumper back from blasting to finish it aswell.
Cheers
Chris
Fordkid68
Post by Fordkid68 »
Awesome! your cruising right along. It looks amazing, and I bet you can't wait to drive it!
Adam
My first truck,
^^Build Thread^^
(no other projects, YET!)
hfdco4
Post by hfdco4 »
Wow, nice work and really nice truck.
:fr: FE390PC
1970 F250 4x4
2016 F150 4x4 2.7 ECO
Gone 1988, 1989 & 1991 Broncs
cash667
Post by cash667 »
:woohoo:
I`M DONE FOLKS :D :D
got the last things finished! What I´ve done:
bought some 69 Mustang door speaker grilles to cover the speaker holes in my doors (with new speakers of course). Looks really good I think:
Got my step bumper back and painted it with the black bedliner. Wasn´t sure about a black bumper but it looks perfect:
I also finished the inner side of the tailgate with the black bedliner and mounted it to the truck. I´m so happy with the look of the rear end...love it 8)
Then I had to mount my outside western style mirrors with the really big mirror panels. I like this "big truck" look, but I made them movable without the necessary of any tools to swing them when I have to pass narrow passages.
And here are the final pic´s with new tires and all done:
I´m so happy with it. Even the old paint looks good and we were able to keep it overall. Needs a bit polishing and waxing, but that´s it. :yt:
Did some test drives with an AFR meter to get a good start on carb tuning and will do the fine tuning whenever I´m allowed to drive on the road legally :lol:
here´s a little "walkaround" video:
https://vimeo.com/530462518
password: f250
Thanks to all of you helping me with advice and sharing your projects for reference aswell. Even a big thanks for the motivation you guys gave me with your comments in this built thread!
:fr:
jimmy828
Post by jimmy828 »
Looks and sounds great. I know you will enjoy it with smiles :thup: :thup:
MAK
Post by MAK »
Just saw this thread for the first time. Not sure how I had missed it. Your project really turned out great. Looking good :thup:
I have a 68 Cougar too BTW, but it doesn’t look near as nice as yours yet.
Fordkid68
Post by Fordkid68 »
Wow, it looks amazing!! The video was cool. It sounds great. What is your next project going to be?
Adam
My first truck,
^^Build Thread^^
cash667
Post by cash667 »
Thanks guys!
:fr:
Fordkid68 wrote:Wow, it looks amazing!! The video was cool. It sounds great. What is your next project going to be?
Thanks Fordkid! My next project will be a selfmade period correct camper shell for this truck :lol:
I´m planing to build it completely on my own. :D
Fordkid68
Post by Fordkid68 »
Oh my! That is going to be awesome! It will really look great on the truck. You are really setting the bar high for the rest of us!
Adam
My first truck,
^^Build Thread^^
67mann
Post by 67mann »
:thup: Thx for all the great Pic's Chris.... I find myself searching for various( :hmm: ) stuff as I start putting more(and More)of my truck back together but, I guess that's part of having one disassembled this long :doh:
hfdco4
Post by hfdco4 »
Great to see a finished project here! I know mine is a SLOW PROCESS but I am trying.
:fr: FE390PC
1970 F250 4x4
cash667
Post by cash667 »
Thanks again guys, you all have great projects and I wish all of you that you get them finished with no major issues - whenever - take your time and stay healthy!
:fr:
By the end of last week I passed the german road safety inspection "TUEV" and got it registered. Now I´m allowed to drive on the roads legally :woohoo:
I also got the "historic" registration which makes taxes and insurance much cheaper.
Don´t wonder about the license plate sizes...this is just crazy in germany... you have to be lucky to get the small license plates like I got on the rear. For the front they refused the small plate on the registration agency. Don´t ask why, there is no rational reason for this..
Anyway, I´m now ready for cruisin and waiting for the weather getting better and chasing after noises which will appear on the first longer drives :lol:
Cheers
Chris
Fordkid68
Post by Fordkid68 »
Very nice! The finished product is absolutely beautiful! What a cool truck.
Adam
My first truck,
^^Build Thread^^
