fuel tank swap.(pics)
Re: fuel tank swap.(pics)
Nice work td,I would think one would want to have just a little bit of the tank to show so when someone ask about it you would have a reason to show and tell about your hard work.I have the same tank on the shelf for "Old Blue" and have really enjoyed your pics.I too look forward to seeing some pics of the rear to see if it shows.I can relate to the "Holding back" of the toy funds as I found out today that my job of eight years will get moved to another state next year.Bummmmmmmer!Anyways,nice work,I love it! Calvin
1967 Ranger,Short bed,390,C-6,9 inch,4 BBL.,intake,cam,headers,3:55 Posi.,A/C,Power steering,Power Disc Brakes,Automatic trans.DJM dropped I-beams,flipped rear hangers,headlight harness upgrade.ExTang tonneau cover "Old Blue".
http://s508.photobucket.com/albums/s328/BigSxy96/
1967 Base model,352,2bbl.,3 on the tree,short bed,3:25 9 inch "Rusty".
1967 Mustang coupe-show car/garage queen.Small Block,alum. heads,Nitrous,4:11Locker,Areospace brakes "Mystang".
1996 F-250 Powerstroke-Big intake,exhaust,injectors.(Nice Smoke Show) "Big Sexy"
- td
Calvin,Calvin Gunter wrote:Nice work td,I would think one would want to have just a little bit of the tank to show so when someone ask about it you would have a reason to show and tell about your hard work.I have the same tank on the shelf for "Old Blue" and have really enjoyed your pics.I too look forward to seeing some pics of the rear to see if it shows.I can relate to the "Holding back" of the toy funds as I found out today that my job of eight years will get moved to another state next year.Bummmmmmmer!Anyways,nice work,I love it! Calvin
thanks for the compliments! i worked my but off on this project, seems i have trouble taking my time with the bump, whenever i start a new project with it no matter how big or small, i go wide open until its done
the recent pics of your truck looks great, what do you lack having it back on the road?
sorry to hear of your job, im just holding on to a piece of a job myself, so i can relate.
TD your truck looks awesome!!!!
Engine to tank, its a beauty!
- td
stangconv,stangconv wrote:TD your truck looks awesome!!!!![]()
thanks so much, compliments such as yours is a big part of the time and effort we put in to our trucks, and its a great feeling to know someone else can appreciate it as much as i do
- 71PA_Highboy
OK,
Confusion time....
Your tank appears to be lower than it needs to be. You have 2 filler neck gaskets and a spacer. Why not raise the tank and elimate the spacer and second gasket? Wouldn't that also hide the tank behind the bumper even better?
just wondering... everything else looks good.
regards,
eric
Confusion time....
regards,
eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- td
71PA_Highboy,71PA_Highboy wrote:OK,
Confusion time....
regards,
eric
i appreciate your observation, i'll explain why i decided to mount it this way. if you'll look closely in the pic below you'll see that the 3rd set (from the front) of bed bolts drop down right on top of the tank, if the tank were on the top frame lip as you suggest these bolts would have to be left out. plus i was worried that the cross support those bolts went through would rest to closely to the tank. i didn't use two filler gaskets, that the one that came with the tank cut in half. i did this to compensate for the small amount of angel the tank neck had in relation to the flat bed floor. see how i straightened some of the angel out by clamping the gasket at an uneven angel. i later clamped the top filler opening and cap in the position its in to help even more. if i hadn't done this the cap would have came through the bed floor at a lot steeper of an angel
than it is in the pic.
Just read all this. Makes me want to get started on my truck. Maybe after holidays I can get started. Again, looks great. John
1968 Ford Ranger Lb
2007 Harley Electra Glide Classic
- td
H-DFord,H-DFord wrote:Just read all this. Makes me want to get started on my truck. Maybe after holidays I can get started. Again, looks great. John
thanks!! we all need a little inspiration.
- 71PA_Highboy
I understand, but I guess it is just a difference of what you are saying and how I understand it.
I was not suggesting that you mount the tank on top of the bed rails, as I understand the issue there.
But...
With what looks to be a great amount of skill you have done some very nice work, so I am sure you have thought this out.... I just am not seeing it in my sleep-deprived head...
Cut the bed bolts .. they are too long anyway.
Cut some new supports for the tank that will fit on the sides of the frame that lift the tank up so that it sits 1/2" below the frame rail (it seems this would give you 3" or so additional clearance).
For the filler neck, just V notch it and weld it back up... that way you can ensure a perfect sealing angle (and eliminate potential points of failure).
As I said, I haven't done this, and I am only working off what I understand... I really am not trying to get you to change your design, just get a better understanding of why you did what you did. I present my thoughts to hopefully allow you to undersatnd my perspective and allow you to address my points so that I may better understand... I always want to learn why people make the choices, and a point/counterpoint discussion seems to be how I learn best.
An additional issue is that I don't really understand your design criteria, so I am certain there are things I am overlooking.
Thanks, and hopefully I haven't offeneded you too much.
Regards,
Eric
But...
Regards,
Eric
Got Ford?
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- marz68
- td
Thanks Marz !!marz68 wrote:That is some nice quality work you did there td
- papabug71
td, thats off the hook. Looks very clean.
I would have never thought of it!
Now you have a TON of room for some subs behind the seat. Im thinkin' a couple of 15's will go nicely!
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
- td
papbug,papabug71 wrote:td, thats off the hook. Looks very clean.I would have never thought of it!
i have plans for some 10's later on when i get the truck closer to a completed state, but for now i'll have to keep listening to the sweet tune of the flowmaster exhaust !!
- papabug71
td wrote:papbug,papabug71 wrote:td, thats off the hook. Looks very clean.I would have never thought of it!
I can relate to that!
Matt
Mine since 5/7/'94
Hey td,what are some of the details of running the sending unit wire?Where did you come through the cab to make the wires go to the rear?I know you probably had to lengthen them,how did you lengthen them?TIA,Calvin
