71 F250 Paint
- rjewkes
Yup its looking good anyways.
fuelly.com
fuelly.com
- Blue Cloud
re: 71 F250 Paint
Well I didn't go fishing today, seems the wife had planned on surprising me tomorrow with a fishing trip so I got started painting the bed instead. Here's some more pics.
- Blue Cloud
re: 71 F250 Paint
Can't help showing off the new window seals.
- wt4speed#2
- Blue Cloud
re: 71 F250 Paint
The cable hanging underneath is a hookup for trailer lights that were in the front of the old bed (fifth wheel ?). I'll unhook the wires later. I'm also changing the tail light harness from the trailer to the pickup as the pickup had been spliced in several places for trailer lights, trailer brakes, and a couple of other things from the look of it.
The tail light harness from the trailer was pretty much O.E. with a trailer hookup that was installed right so I went with that. I'll have to figure out the trailer lights later. Also discovered my rear axel seals are leaking again, this is the second set I've put on it so will have to see whats going on there.
As you can see there's a few more things to do before it hits the road again, but when it does it should be in alot better shape.
- rjewkes
looking good.
fuelly.com
fuelly.com
- wt4speed#2
- Blue Cloud
re: 71 F250 Paint
Texas in the summer time! I'm afraid the heat and humidity would kill this old fat northerner.
Re: re: 71 F250 Paint
Check your axle vent and tube, make sure it's not clogged. During normal operations a certain amount of pressure builds up inside, and that pressure needs to exit, via the vent tube. If it's clogged, then the pressure finds the next easiest exit route, which is past the seals.Blue Cloud wrote:....Also discovered my rear axel seals are leaking again, this is the second set I've put on it so will have to see whats going on there.....
I was gonna tell you that you have a nice-looking box, but for some reason that just sounded very odd.
- Blue Cloud
re: 71 F250 Paint
I just came in from rolling on another coat on the box, it's pretty windy here today and cottonwood fluff stuck to the wet paint in afew places.
I'll have to wet sand that out next time. If it's not gnats, or dog hair, it's cotton fluff! (man, I need a shop!)
Yeah Keith, that "box" phrase crossed my mind too,
just have to give it lot's of caresses.
- wt4speed#2
- Blue Cloud
re: 71 F250 Paint
Hey wt4speed, hope you didn't get caught in that flood in Ft. worth, sounds bad on the news.
- wt4speed#2
- Blue Cloud
re: 71 F250 Paint
I only got one thing done today, my vacation's over and I sat all day waiting to get called to go to work. Anyway, I painted the letters on the tailgate, rolled them out with satin white Rustoleum. Here's some pics.
- kaptnkaos
re: 71 F250 Paint
that really looks sweet BC...
Thanks for takin' the time to do a step by step thread with pics.
Personally, I appreciate it.
I was thinking about trying this myself after reading the thread from the other site about the Charger. Now, after seeing you do it step by step, and seeing the results come together like they are, it isn't nearly as scary as it was. I am definately gonna do mine that way.
Do you recommend dismantling it like you did or can you do it whole with and only remove the trim?
Thanks again,
KaptnKAOS
Thanks again,
KaptnKAOS
