Sargent! Now it became a bit difficult to understand.
I've had the whole steering column and at the bottom of it I have no such # 1 as your picture? (# 1 The bottom of the shift tube) There is only one layer in the sluice there. (See my picture on page 3)
# 3 The lower column shift lever has a slot that slides the tab on the shift tube. It seems good when I checked it when I had the whole steering wheel out? Now it became difficult. please try again to explain in an easier way how to test so I can find the error. Do I have to remove the whole steering column again ... suck.
(# 2 The top of the shift tube sits in this sleeve on the underside of your shift collar. It sits firmly in the sleeve. You should not be able to remove)
I do not understand this. How do you mean? I know when I had to put it back I had to turn and push it into a track and then I screwed it tight with those two stupid screws sitting in a slot on the back ?? Could it be where the fault is? how can i do to see this ??
(# 4 The tab on the shift tube sits in the shift lever) Here I think it's ok. But how should I test if it's wrong there?
There were still many questions for you today again.It's hard for me to understand the translation sometimes, so I'd rather ask for too much time.
This seems to be a difficult problem to solve ...
but I will solve this until the end.
