from beginning to end!"Project: Big Nell"(11/1/07)
- Big D's 69
Looks like it is definately coming along.
1969 Ford F-100. 302 4 barrel, C4 auto, 9in 3.50 open rear, headers, power steering, Turq/wht, Under restoration. In other words, in a million pieces!!!
There is no Replacement for Displacment!!!
My Photo Gallery: http://www.fordification.com/galleries/ ... ?album=655
re: from beginning to end!
its actually a VERY solid truck compared to some i have seen. The motor is the eyesore.....not for long
- rjewkes
Now its looking better. Get rid of the grease crud and rust and she'll be in good shape in no time.
fuelly.com
fuelly.com
just an update.
the long block accessories are off. Heads come off later this afternoon, or tomorrow. It Turns over no problem, not catches, no grinding. After talking to people here and there, some local, some far, I have come to what I want to do process wise with the motor.
I am going to re-ring the pistons, and hone the cylinders, given they are in a condition not needing a bore. New bearings, acid dip the block and heads, and possibly have the heads rebuilt if needed. This should "refreshen" the motor, but not rebuild.
well, its been a little bit....
The motor was taken to the machine shop for rebuild. Only needed to be bored out .030 over, and the crank was turned down .010, not bad I don't think. I have to take him a few more pieces, but other than that, I am on my way to....dare i say...a RUNNING TRUCK! Hope to order my weiend stealth intake, and start on my brakes shortly
. All new drums all around, may get away with just new internals....probably not though. Atleast I can use the rear drums once my frame is built, for a while anyways.
I will get some more of the progress I have made cleaning up the front frame and firewall. Its getting there, but having the wiring harness in, has proven to be a pain........and it's a hack harness anyways. Just want it in long enough to run the new motor in the garage for a while. Let the rings seat and everything, then I will drain it and add my own oil and stuff, run it a bit, then it's on to building my frame
This is a picture of the truck prior to getting pressure washed. Can anyone tell which side of the motor was leaking?!?!
Alright, this set of pics is after I rolled it out of the garage to get a bath, and rolled it back in.
Now, this is a HUGE improvement over how it was when I got it.
Motor loaded up, and headed to the machine shop/engine builder! Just going for a stock rebuild, nothing fancy. Just want it to move
Oh, and yes the hauling truck is a ford
06 F-150 I believe, might be an 07?
yah, once it was opened up I knew it needed it no matter how bad I didnt want to do it. So I took the plunge and had it worked over. Should run like a top when its done
let me say this.....while aircraft stripper may work, it only works on ***** paint. It ook the top layer of primer and crap paint off in a heartbeat, but the original paints, it just wouldnt budge hardly.
So off to lowes I went. I picked up a air rotary tool, and some paint/rust strippers which in my eyes, after tonite, are god by all means of paint removal. I only got three, and went through about 2, maybe a little less, but not worth really using the second anymore other than large flat areas.
On to the pic of what got done.
me hard at work.
not a TON, but it is a LOT compared to what the aircraft stripper did.
me hard at work.
