67' longbed build
- popeyes71
Re: 67' longbed build
Nice, more new parts!
Your making some nice progress on the truck!
-Popeye-
1971 F-250 4x4 Highboy
Been too long. Lol.
Pix and updates! W00hoooo
Guy i know, got a 79 vw bus and has been sanding and gutting it. Soooo.
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
2014 audi tt Quatro s
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
New bottom door window felt is from ebay. Cheap and easy job. Takes 10mins if that. I used a flat head screwdriver and pryed the old half gone/rusted ones out. Popped new ones in. Just roll the window down. Easy peasy.
I also recommend new rubber channel runners that go up the sides of the window. I havent done this yet but looks just as easy and will keep ur window tight.
Hoping to get to metal work very soon. Ive been sanding my cab for 2-3 days now. 2-4hrs each sesh. I plan on replacing the bed rather than plank it with wood.
Truck just dosent seem old enough to have the wood bed. Should b metal imo.
D
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Its the small things in life like carpet and an am/fm cd radio in ur truck!
Also come with lots of size C batteries... the radio does... not life. Lol.
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Truck did ok on its 3hr eastern WA run. On the way back... i ran dry of oil and water. I think my truck has blow by and needs a compression test and such. Could b my back rear main seal but idk.
Anyways. I stopped and pulled over when i saw my temp spike. Header wrap was on fire! Lol. Oil and heat BOOM. Fire. Lol.
I got to cle elum and got a qt of oil and dumped it it. Put all the water i had in it 1st stop with the fire. Put more water in.
Temp was jumping the way back with all the bubbles and low fluid.
When i got home and checked the oil. It was empty. :0
Lucky i made it home.
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Truck was indeed blue at 1 point. Makes me believe even more so its the same truck as the older pic i found.
D
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Well tried to take my passenger fender off today. Broke two bolts and got what i could off. 3 more from what i can tell.
Sprayed wd 40 but its gonna rain i guess tonight.
Man i dont miss this. Taking it slow as usual.
Shell b purdy 1 day. Im taking a liking to that new ford sparkly brown.
-d
-d
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
- Manny
Hey your out your enjoying it, and that's what matters. The motor using a quart is not a massive thing. Especially in 6 hour cruising round trip. Using the coolant is more trouble it seems. coolant smell like fuel/ combustion. Mine does in the 74' bronco.... But hey they are just a lil old. Glad your driving it and runnin it that's what matters!!
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
- popeyes71
Like the rest of the folks said, at least your out there enjoying your truck! Cool to see her on the road!
-Popeye-
Got the passenger fender off and replaced. Now my passenger door rattles when im driving. Great. Lol.
Really need upgraded or fixed and working properly brakes. I almost rear ended someone tonight. Looked down for a sec and back up to a red light and the person in front of me slamming on the brakes. I had to curb it and run the red. Glad the person waiting at the light to turn was paying attention.
Next things to tackle would b brakes, metal prep, gas tank empty and clean.
Lord knows what else! Keep it real ppl. Ford on!
-d
-d
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
well. Heres my fenders and hood. I have to jump up and put my scrawny butt up on it to seed it down. Im in need of new hinges and springs and I think itll line up alright. Not good but alright.
have a good one all!
-d
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
As far as the brakes go you might access the condition of your front end. Mine was actually in pretty good shape and I strongly considered doing one of the swaps that use the drum brake spindles but I wanted it all Ford so I’m going to do early dent spindles and swap to early dent tie rods, do the bushings and all - I’m going to end up with as much in it as one of the bolt on kits, but it won’t be a heinz57 of parts. I doubt that it will stop as well as something like the SSBC kit, but it’ll also be stealthy...
Only thing ive done to the brakes is change the master and passenger side cylinder. Top off fluid as well.
Ive been shopping and looks like for front disk brakes, lines, and new master with booster and such. $1000 or a little over.
https://m.ebay.com/itm/65-72-FORD-F100- ... %7Ciid%3A1
D
Edit. I didnt bench bleed my new.master. just cracked the lines after install. Nor have i bled my wheels. Figure theres no point if i cant even keep the 1st resivour full in the master. Need to replace the other front.cylinder and lines 1st.
-Double D
D
-Double D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
