upside down i beam?
- boots
re: upside down i beam?
link is just a blank page
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
It's a problem called "site owner has a small weiner," I think. You can get there, you just can't get there from this site.
Copy it to your clipboard, close your browser, reopen, and paste URL in.
- Heavenlyfire
Ok, here are the "pre lift" measurements. ( plus a couple my wife said I have to throw in). This coming Thursday morning it starts!! Wish me luck.
An Arizona resident wearing a Big Red t-shirt??
Cool!
Good luck!
Good luck!
- Heavenlyfire
Every summer I went to my great grandmas, St Paul, Neb. It was bread into me. GO BIG RED.
- rjewkes
Actually I agree with keith it would give you opposite caster of what you got now. Instead of / you'd Have \ or instead of \ youd have /.
either way you would probably have to have the caster changed by a good I beam place probably a Deisel repair shop they have I beam Front suspensions all be it single I-beam. Or they would know a place that could help you.
fuelly.com
fuelly.com
- rjewkes
Basically Caster is where and how the steer tire(s) Trail the axle at all speeds and effects Steering return.
So if the castor is like this / right side up, swapped and upside down it would do this \ and would have negative caster.
as opposed to just swapped wich would do this / to this / just everything backwards. I thought that like the 80-93 I beams the 67-72 had one side shorter than the other is this the wrong idea?
fuelly.com
fuelly.com
- Heavenlyfire
I got under and measured them in the truck and they seem to be the same length. I am worried about the tire angle though. I will just have to wait and see what it looks like.
- Heavenlyfire
Got the radius arm bushings ordered and I think I am set to get started. I have come to the conclusion that the camber may be off a little but I might be able to fix it with a couple of well placed shims.
- rjewkes
If it works out i will not knock it.Good luck. as caster and camber go you could have a diesel alignment shop bend the i beams for you.I think.
fuelly.com
fuelly.com
- Heavenlyfire
Ok all this is really turning into a project. The farther I go the more I find wrong
. I pulled my drums off to replace the brakes while I was there. Passenger side has over 1/8 inch grooves in it. Theres another chunk of change. But I am continuing on.
- Heavenlyfire
Was going to take some pics for everyone, the dam batteries in my camera are dead
. I will have to wait till the wife comes home and go get some. Anyway, I've got it apart and have a lot of cleaning to do before it goes back together.
- boots
cant wait to see pics
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- Heavenlyfire
UPDATE UPDATE UPDATE
So far so good, 4 1/2 hours to get the front end out, and a couple of parts cleaned up for new bushings. Final measuring done, they are exactly the same length so no problem there.
Heeerrrreeee we go.
Heeerrrreeee we go.
- Heavenlyfire
By the way Boots.
My wife says thanks for putting the idea in my head
