custom gauge panel, i got started.(pic)
- rjewkes
is that a tilt colum outa a 78-up?
fuelly.com
fuelly.com
- td
thanks guys, i'll be proud when all the wiring is done tomorrow. here's a link to the led's i used. http://www.watsons-streetworks.com/ligh ... pment.html they are very cool and yes they are metal bezel around the led's. rjewkes, yes the column did come out of a 78 lariat.Mugwump wrote:Nice job, td... that looks real nice! I'd like to know what you used for the turn/hi-beam indicators. Are those LED's with metallic bezels?
- td
re: custom gauge panel, i got started.(pic)
well its all in and wired up,and everything is working correctly.i checked the speedo and its right on the money. man what a wiring jog that was! all in all i don't think i gave this project the respect it deserved in how big a job it was going to be, but its done
- wt4speed#2
- td
Very Nice! People like you motivate me into MO Money MO Money MO Money.Keep up the good work. Calvin
1967 Ranger,Short bed,390,C-6,9 inch,4 BBL.,intake,cam,headers,3:55 Posi.,A/C,Power steering,Power Disc Brakes,Automatic trans.DJM dropped I-beams,flipped rear hangers,headlight harness upgrade.ExTang tonneau cover "Old Blue".
http://s508.photobucket.com/albums/s328/BigSxy96/
1967 Base model,352,2bbl.,3 on the tree,short bed,3:25 9 inch "Rusty".
1967 Mustang coupe-show car/garage queen.Small Block,alum. heads,Nitrous,4:11Locker,Areospace brakes "Mystang".
1996 F-250 Powerstroke-Big intake,exhaust,injectors.(Nice Smoke Show) "Big Sexy"
- 69NVF100
Td, Your truck is my favorite truck on this site I love the stance, wheels, motor and gauge cluster.
Your truck definitely ROCKS!!!!!!
- td
thanks for the compliments, being able to share all the mods i do with a bunch of guys and gals that love these trucks as much as i do is awsome. NVF100, i sent you a P.M.
- 69NVF100
P.M. replied to thanks td
- green70
did you use electronic or mechanical speedo,how does it hook up,i plan on doing something very similar....
- HRDROKN
Re: re: custom gauge panel, i got started.(pic)
I like it!td wrote:well its all in and wired up,and everything is working correctly.i checked the speedo and its right on the money. man what a wiring jog that was! all in all i don't think i gave this project the respect it deserved in how big a job it was going to be, but its done.
'69 Ford Cummins Crew Cab... Built 6BT main & head studs, ported & oringed head, springs, Ti retainers, marine cam, tweaked P7100, 4K gov kit, NV4500 w/1.375" input, Southbend 3600# DD clutch, NP271 w/SYE, D60 HP front, high steer, 16" coilovers & 4-link, D80 w/disc rear, 4.10's & LSD, spinning 38" x 14.fiddy's on classic slots..... more coming!
http://www.fordification.com/forum/view ... hp?t=23267
- td
green70,green70 wrote:did you use electronic or mechanical speedo,how does it hook up,i plan on doing something very similar....
i used a mechanical speedo, and it is a direct fit to your stock speedo cable. i was even lucky enough not to have to change the cable gear it was right on the money.
HRDROKN,
Thanks!!!
