67 Project Update 6/1/2023 (Multiple New Posts With Pictures)
- rjewkes
good deal. i have used one to lift a motor to get to the mounts and freeze plugs.
fuelly.com
fuelly.com
- craftsman
re: My 67 Project (Update 5/11) Pulled Engine, W/Pics
Good job on that pallet there jww
moving right along with the project
. Sometimes i fill mine just sitting patiently, i have to many house projects going right now, but i will be taking a break from that and work on the bump soon
- JWW
re: My 67 Project (Update 5/28)
Trying to remove the front suspension on the 67'. Getting those radius arms out is difficult. I'm also trying to break down the suspension I got off of a 75' donor. Again, the radius arms are tough. I'm soaking them with some AeroKroil:
I really like this stuff. Hopefully it will help loosen the radius arm bolts. I don't know if it is me or not, but the Ibeam on the passenger side of the 75' set seems to be bent or off set. I don't know if it is bent or if that side is supposed to be that way.
One of the nice things about were I work is that I have access to a hydraulic press. I plan to get some of the guys in the tool room to press out my king pins for me.
More to come...
More to come...
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
2004 F150 Crew Cab
- JWW
Re: My 67 Project (Cart before the Horse???)
Been a while since any updates. I'm a pretty fair weathered kind of guy.
I have been practicing on the welder, but I cannot decide if I should work on the cab first or get a rolling chassis first. What are some of your thoughts on this? Does it really matter?
Thanks
Thanks
JWW
2004 F150 Crew Cab
2004 F150 Crew Cab
- dablack00
Re: My 67 Project (Cart before the Horse?????)
For sure finish the rolling chassis first. Be done with that and then you can set the cab on it and work on it there. If you need to work on the bottom of the cab, just put some cushions down and roll the cab on its back. Finish the cab bottom, then roll it back on the mounts. Then finish the rest of the cab. On our trucks, when the rolling chassis is done, then the cab is done, you are 90% there. With the front sheet metal off, you can perfect the engine and firewall (with wiring and other bits). Then just hang on the front sheet metal and place the bed. DONE!
- JWW
Hey dablack00, thanks for the advice.
JWW
2004 F150 Crew Cab
2004 F150 Crew Cab
- powerslave390
Hey JWW, Adorable little helpers you got there! Your project is looking great, keep up the good work and keep us posted.
- JWW
Thanks...at the rate I am going, they will be old enough to drive when I get done.powerslave390 wrote:Hey JWW, Adorable little helpers you got there! Your project is looking great, keep up the good work and keep us posted.
JWW
2004 F150 Crew Cab
2004 F150 Crew Cab
- powerslave390
I am working on a 1970 F100(custom frame off restoration) with my son, so we are right there with you. Keep it up!
- rjewkes
yeah with a rolling chassis to sit the cab on, especialy with running engine, you can sidestepp a nosey city/county code enforcer curious about your project.
fuelly.com
fuelly.com
- JWW
Cool thing right now is I have good neighbors. They have been supportive ever since I brought "Mater" to the house.rjewkes wrote:yeah with a rolling chassis to sit the cab on, especialy with running engine, you can sidestepp a nosey city/county code enforcer curious about your project.
JWW
2004 F150 Crew Cab
2004 F150 Crew Cab
- rjewkes
Your lucky there, my problems started when i first started the towing job, my tow truck wich was an f650 with a 21 foot rollback/flatbed took up three spaces parked sideways to keep from sticking out in the middle of the lot, and the F100's front end was taking up a space to itself, Wich the church has never cared about and its their lot to care about. Anyways A guy in a Brand spanking new Chevy Crewcab almost hit the front end of the f100 becuase he has every right to park there for the Christmass parade went to the city and moaned about his new chevy almosty getting damaged.
Long story short it was easier for the city to enforce a code written to keep people from piling up 5 or more junkers, on my one junker, than to tell him to watch where you are driving/parking. This guy would try to park on a land mine in afghanispakikazhakstan and moan to the state department about it.
fuelly.com
fuelly.com
- JWW
Re: My 67 Project-Floor pan install 2/21/10
Got my floor pans installed today. A buddy of mine did the work in his shop. He will put the cab mounts in next. This is a big step for the project because it has stalled for quite some time. Looking forward to getting back at it.
The pans are from BOTP.
JWW
2004 F150 Crew Cab
2004 F150 Crew Cab
- 67mann
Stalled---your still messin around with thisJWW wrote:Got my floor pans installed today. A buddy of mine did the work in his shop. He will put the cab mounts in next. This is a big step for the project because it has stalled for quite some time. Looking forward to getting back at it.
Looks good
Better get those cab supports (WOW does that look familar)taken care while your there too
- basketcase0302
JWW,
Looks good man!
You and Jerry both are doing it right, for sure.
Maybe someday I'll be able to do this part of my truck.
How quickly is the shipping from BOTP? I've never ordered from them before, just wondering...
Looks good man!
