coil or relay?
- 19674x4
its really weird because i started it the day before with it in neutral and no clutch then i changed the alternator and went to start it up and no go. the only thing i can think of is the ground on the alternator is not grounding but i put it on the post that said GRD
My Photo Album
- 19674x4
i havent had a chance to cross the sylonoid, what two posts do i need to cross, the one from the battery and the one going to the starter?
My Photo Album
- 19674x4
i disconnectd the neutral safety switch a long time ago. today i put a fresh battery in it and still nothing.
My Photo Album
- 19674x4
well i dun it but nothing happened- no spark or nothing, that usually means the solonoid is bad right? or could it be my negative battery cable. keep in mind i just replaced that alternator so let me know if i could have screwed up there to. the only other thing i have not done is checked the fuses underneath the dash.
My Photo Album
- 460 crew
re: coil or relay?
When ever you replace an alternator it's a good idea and recommended to change out the voltage regulator. I recently had some starting problems and ended up replacing an ignition switch, started solenoid, Alt, battery and coil. Ended up my problem was the positive wire on the Alt was breaking apart and was only making contact on vibrations, in turn it wiped out my voltage regulator and killed the Alt. When I replaced the alt and no voltage regulator it overcharge my fairly new optima and blew acid all over my engine compartment. So back to the store for a voltage regulator and a new red top. lesson learned. Like stated above check your connections even where you have factory connectors for decaying.
- 19674x4
i changed the vltage regulator.
My Photo Album
- 19674x4
re: coil or relay?
i get a dunce cap
i had my battery cables on the wrong posts, no it starts fine
My Photo Album
