Critique My Welding
- flyboy71
Re: Critique My Welding
Not meaning to hijack the thread but since were talking welding does anyone know the proper way to plug weld a panel that the spot welds were drilled out? I see some say just make circles, some say start at the edge of the hole and some say hold it vertical and just fill the hole with a puddle. I can fill the hole but my MIG sputters and my spot has too much dome. I need more practice too Im sure.
-Jeff
1971 F-100 240 straight six, 3 on the tree (parted out)
1972 F-100 302 auto trans, pwr steering, pwr brakes (under construction)
"Things are more like they are now than they ever were before" Dwight Eisenhower
-depending on the size of the holes you're filling often times you can use a nail as a piece of filler and then cut/grind the excess off
-if you're just plug welding basically make a little circle (if its a larger hole) and if you can,use a backer -a piece of copper, anything from a penny to a crushed piece of copper pipe ,the weld won't stick to it and it'll make your life a little easier
also flat position welding (the work piece is horizontal) is the easiest and most efficient -not always possible to do tho'
- still got my first first car 20+yrs later : 69 f100 sorta kinda pretending its a Mercury M100 w/a 70 f350 sport custom cab (factory buckets) 67 grille with 69 ranger cooneyes 68 merc box and hood,some supercool fiberglass fenders i scored way back when, 76 f150 disc brake frontend..currently running a 90 5.0HO 4bbl/c4 auto & 3.50 posi...originally a 360/c6 f100 Ranger with dealer added towpack (incl. kelsey hays trailer brake),boxside toolbox,behind the seat stowage & belly tank...only original parts left on 'er are the frame,rear end,rear springs,and rear bumper...
