leaky water pump bolt
Re: leaky water pump bolt
Permatex makes the Right Stuff it replaced the old brown Permatex sealer and cleans up easier. It comes in a can with a dispenser nozzle and handle. It is black and acts like a cross between the brown Permatex and a very good silicone sealer.
- leavittt
I have to agree with Dragon- Right Stuff is worth its' weight in gold! I work at the BYU autoshop here in Provo & we use that on all our GMC intake manifolds, water pumps & differential covers. We have done literally hundreds of them & I have never seen one leak so far.
1970 Ford F100 2WD SB 447 Strokered FE w/ T19
- floyd67
thanks i will have to look for that
1967 f1oo "floyd"
2013 f-150 DD
2005 audi a4 (wife's car)
2013 f-150 DD
If you use right stuff do you still use the gaskets and coat both sides of the gaskets or eliminate the gaskets?
- Manny
I have seen people just use right stuff or just give a thin coat on the gasket. 3m use to sell silicone strips you out on and mushed together to make a true seal... don't know if they are still out there.calvinstoy wrote:If you use right stuff do you still use the gaskets and coat both sides of the gaskets or eliminate the gaskets?
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
- Ron_Hall
Great stuff!!floyd67 wrote:took it apart again, waiting for it to dry again, what is this "right stuff" you speak of?
Ron
1971 F100 SWB 390 FE - bored.030 over
Edelbrock Performer - Holley 600 CFI
Stock heads with some porting - Sanderson FF427 Headers
C6 with stock converter - 3.25 rear end gears
One owner...
One owner...
