Mine is out the back. I wanted them to come out at the rear corner behind the wheels. Kind of tucked up with a turn down right at the ends where you don't see the pipe just the ends pointing downward. Shop said he couldn't do it because of the springs and hitch. I have the larger tips with the slash cut I guess you call it. Gets a little loud once in a while with the Hooker Aeros-chambers but no resonance. I wonder if the tips make it louder?
clint
where does your exhaust exit?
Re: where does your exhaust exit?
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
Mine is out the back now... I'm thinking H pipe w/ some kind of tube muffler and out the side on a angle w/ rectangle pipe close to the bed to give it a sleak look and cut the pipes to match the body line.
- 1966 Ford Mustang (My First Car)
- 1972 F250 360 3-speed
- 1984 Bronco
- Redcap
I'd be looking for a different shop next time, then.cdeal28078 wrote:Mine is out the back. I wanted them to come out at the rear corner behind the wheels. Kind of tucked up with a turn down right at the ends where you don't see the pipe just the ends pointing downward. Shop said he couldn't do it because of the springs and hitch. I have the larger tips with the slash cut I guess you call it. Gets a little loud once in a while with the Hooker Aeros-chambers but no resonance. I wonder if the tips make it louder?
clint
At least he was honest about his capabilities and didn't try, make a mess out of it and try and charge me for it like some people would have done. It is pretty tight under there for a 2 1/2" pipe the way I wanted it done and he is always very easy on the price.
I took him my 2 Hooker Aero-chambers and he ran true duels with 2 1/2" aluminized pipe and large chrome tips all the way out the back for $200. Couldn't beat that anywhere else around here.
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
Out to the side behind the back wheel. I don't like them out the back being
as I have a camper shell. If you have them out the back, in some cases exhaust
can flow up and in through the back of the truck. Then you get to smell exhaust.
I've seen this on station wagons too.
1968 F-250 / 300 six / T-18
Dana 60 - 4.10 Limited Slip
- 91Bear
- gregamorton
1967 mercury F350 7.3 IDI ats turbo kit c6 gear vendor overdrive 3.73s rolling on 19.5s
1971 sport custom on 1979 f350 highboy frame 460 c6 np205 dana 60s 3.54s
1974 F100 baby blue & rust 240 3 speed 3.70s sitting on the ground!
1990 F250 extended cab FI460 e40d 3.55s daily driver
Possibly looking for my next bump right now!
