1963 F-350 Cab/Chassis -- IT'S ALIVE!
- ezernut9mm
Re: 1963 F-350 Cab/Chassis -- IT'S ALIVE!
the y blocks have adjustable rockers. could need the lash set.
- reflectionpoint
This has a 1970 390FE 2BBL swapped into it.ezernut9mm wrote:the y blocks have adjustable rockers. could need the lash set.
Life's a beach.. then you get swimming lessons.
--'72 F102 LWB, RWD, 390 FE, C6, 3.50 Open 9", Current Project.
--'63 F350 LWB, RWD, 390 FE, T18, 5.13 Open D70, future car-hauler.
--'94 Explorer Limited, 4x4, 4.0 Cologne, Auto, 3.73 LS 8.8", Kid Hauler
--'93 Dodge LWB, 4x4, 12v Cummins, Manual, 4.10 Open D60/D70, Newest member.
- rjewkes
Wait i thought all lifter/rocker pushrod engines had Valve lash?
Did/ do the FE's not have a valve lash?
fuelly.com
fuelly.com
- ezernut9mm
i thought fe's were "self adjusting". maybe i am using the wrong terms.rjewkes wrote:Wait i thought all lifter/rocker pushrod engines had Valve lash?![]()
- ezernut9mm
if it is an fe and has some "ticking" it is probably an exhaust leak.
- reflectionpoint
Ya the FE's have hydraulic lifters so they self adjust..except very early 352ci FE's (I think). My thought was because it sat for nine years without being run one of the lifter's is stuck in whatever position it stopped in nine years ago..so it's ticking. It's not an exhaust leak, my F100 has one of those and that's a much slower and lower pitched puh-puh-puh sound.. not the typical faster higher pitched tat-tat-tat valvetrain sound.ezernut9mm wrote:if it is an fe and has some "ticking" it is probably an exhaust leak.
At any rate my intention is to pull this motor and at very least replace all the gaskets. I'll likely to some port work and put in a good low RPM torquey cam like CompCams K33-221-3. Maybe something a little more aggressive but not to much. This is gonna be a lower-RPM stump puller type rig so no need to rev to the moon.. any other suggestions to help in the torque department? I'll be adding quite a bit of weight by lengthening the frame and adding the bed, as well as PTO driven hydraulic pump for the winch, etc.--plus actually you know, putting a car on the bed.. haha.
