Engine Swap Question
flyboy2610
Re: Engine Swap Question
Post by flyboy2610 »
A properly built C4 will take anything you can throw at it. I don't know that I'd put a stock C4 back there, though.
Might be OK, but.........
Red Green
you'd better be right.
tybob81
Post by tybob81 »
I have a dumb question possibly. I thought the FMX and C4 were different trannys. I was corrected by a buddy of mine when I asked if he had any C4 out of any mid to late 70's LTDs with 351/400m. He said they had either a C6 or the FMX. Is the FMX a newer C4. Like GM did with there (weaker)metric trannys of the same year?
1968 swb hydroboost, ididit tilt column, Saginaw p/s pump with F series serpentine, all led lights, Vintage Air and painless wiring. 393w, tko600. CV front suspension w/c5 calipers and gt500 rotors. Stock Flexomatic leaf springs with 01 CV 8.8, 3.90 gears and Auburn locker. Custom wood bed floor. Full frame off resto-mod.
BobbyFord
Post by BobbyFord »
FMX's were used in various vehicles from '68-'81
C4's were used from '64-'81 when they were replaced by the C5 (which was basically a C4 with a lock-up converter).
FMX's were kind of like a medium duty trans. They also had a weak spot in the case at one of the band anchors, where if you beefed up the valve body, would shift hard enough to crack the cast iron case at the band anchor.
tybob81
Post by tybob81 »
Ok so the fmx is ruled out for being behind a beefed up big block. :D
