the bump wont start
- 1971ford
Re: the bump wont start
the choke isnt hooked up, thats one of the things on the to-do list. we just have to manually open/close it
-Ryan
- SteveC
that maybe your problem on a cold day.
AS cold as its been here i have to choke the truck to start it and then i push the choke fully open and just let it idle for a couple minutes before i go.
Is it a electric? manual? or heated
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
- 1971ford
its an electric choke on a edelbrock carb. any idea on how to hook it up
-Ryan
- SteveC
the electric choke needs to be hooked up to a hot when the switch is on. Best place if i remember correctly is the stator wire on the alternator.
I've personally never had a electric choke..i think there is something you have to do to set the choke before you try to start.
Something like turn the switch on and push the gas pedeal to the floor once and release.
though i could just be crazy... If you still have the instructions to the carb they can also tell you how to hook up the choke
1967 f-100 4x4
1967 f-100 4x4
