Hey, can ya'll help an EFI generation kid with some links to duraspark info? Wanna learn whats in the older rigs.
Adrianspeeder
Duraspark question
- adrianspeeder
'08 F-250 Spartan Tuned 6.4L PSD ZF-6 4x2 XL, Reg Cab,
'02 F-250 Vin Diesel 7.3L PSD 4R100 4x4 XLT, Crew Cab,
'97 F-150 Dad’s last truck 4.6L M5OD 4x4 XLT, EX Cab,
'79 F-150 Homebrew Dually 351M C6 4x2 Lariat, Reg Cab,
'71 F-100 Bump 302 4x2 3/tree Stepside Custom, Reg Cab,
'66 F-250 Slick 352FE 4x2 3/tree Custom Cab, Reg Cab,
Broncos: '94 Grandpa’s mint daily driver XLT 302 E4OD,
'92 Momma’s daily driver XLT 302 M5OD, '88 OJ XLT 351 C6, '84 Mint! Lariat 351HO C6,
USAF TSgt C-17 Aircraft Maintenance Flying Crew Chief & Flightline Avionics Craftsman
- Clarko
- splavin90
- 390Nut
Sure!adrianspeeder wrote:Hey, can ya'll help an EFI generation kid with some links to duraspark info? Wanna learn whats in the older rigs.
Adrianspeeder
Se my sig line below to add to the links above.
`69 F100 390 4spd driver
Pipes71 did once say, "bumps and bikes.. what a great combo!"
is there a specific coil to be used with the red module ?68F250 wrote:Personally I like the red one best. California-only high output module with variable dwell to maintain coil saturation, didn't use a resistance wire, designed for a .060" plug gap, will knock you on your butt.
If I remember right, black and green are the older units, blue is the most common, red is CA only, white has a crank retard, yellow is the dual-mode with a run retard, there's another one I can't remember right now.
- willowbilly3
