Master cyl
Master cyl
Whats the proper way to bleed out a master cyl while still in vehicle
.1968 F-100 manual brakes. Thanks guys
1968 F-100 Custom Cab
300 6cyl 4spd
If it ain't broke,what the hell, fix it anyways !
300 6cyl 4spd
- heep70
re: Master cyl
Start with the longest brake line first and work your way to the shortest line.
Brake the bleed valve loose, place a vac hose on the bleeder and the other end in a jar of brake fluid. Not full just enough fluid so the hose is under. Open the bleeder a couple turns. Make sure the MC is full. Semi slowly pump the peddle 5 - 10 times. Close the bleeder and fill the MC and go onto the next. If you let the MC go dry you will need to start over.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
