460 engine perches
460 engine perches
I'm going to install a 460 in a truck that is supposed to have had a 390 but currently has a Chevy 350. I have the factory 460 perches and mounts will the perches bolt in the same holes in the frame or will I have to drill new ones. Nothing against Chevy motors but they need to stay in chevys
Re: 460 engine perches
Here is a technical article that talks about engine perches, it does mention the 460 engine, not sure if this helps, but here it is:
http://www.fordification.com/tech/engine-perches.htm
Regards
Regards
if I remember right mine pretty much bolted on.
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
