first I wanted to pull only the transmission to let it rebuild by a pro. But in the meantime I have read a lot of threads here and there seem to be some problems with it by pulling the trans only. The most important seems to be the crossmember which fits very strong and is not only a bolt-on-construction... Wrestling with it under the truck on wheels without a lift for the truck could be some PITA I read between the lines. Some bolts are also not an easy access. The crossmember in front of the truck is also the third engine mount so this could be also worth some trouble.
Engine-wise I saw that there are some leaks which I wanted to deal with later. It seems that there are perhaps leaks on the valve covers, rear and front main shaft seal, the oil pan, the thermostat housing, perhaps the waterpump-housing and the freeze plugs seem to have seen better days, too. So my thoughts are now if it is not better and easier to pull the engine and the transmission in one and do it right.
What do you think? Would that be the right decision and the easier thing?
What have I to do to prepare the pull of both? Would it be enough to remove the front bumper, grille, grille support, radiator and radiator support to get an easy entry with an 2-ton engine lift and pull it out? How is the clearance on the sides with the inner and outer fenders on place? Do I have to remove the exhaust manifolds? Which external things I have to remove also?
I once pulled the engine of the Mustang Mach 1 but that seems to be a whole different thing - much less space for all and the radiator support and other things wasn't removable...
Now after the engine is out - which things would you have to look for other than the above mentioned? In the first instance I do not want to make a complete rebuild. If the drivetrain is all ok I do not want to change a thing. Change all the seals is one thing. But for example if the intake seals seem so be alright would you change them nevertheless? Or the head gaskets? I do not want to pull anything if not necessary, the engine starts immediately and purrs like a cat! What's your opinion on this?
If the engine is out it would be the best to have a look on one or two of the bearings of the crank and the rods. If they seem ok, let them be, should I? Butchange the timing chain, waterpump and oil pump anyhow? What do you think? Which are the musts, the do-nots and the perhaps?
Much text but pulling an engine and a transmission with some work on it is not an every day case so sorry on that
Thank you very much,
Tim
