Swapping Oil Pan 68 F100 390
erikhillard
Post by erikhillard »
Looking for an oil pan for easier and cleaner oil changes. I read in the FAQ that a FE engine rear-sump oil pan would accomplish this?
Any drawbacks of making this change? Reduced ground clearance?
By changing the pan, is there anything else that also needs to be changed? I've never swapped pan designs before.
Would this be the correct pan?
https://www.cjponyparts.com/oil-pan-sto ... sMEALw_wcB
Best,
Erik H
1968 F100 Ranger
California
tnlprt
Re: Swapping Oil Pan 68 F100 390
Post by tnlprt »
A piece of cardboard from the case of oil you bought works best
Factory rear sump pans will hit the steering linkage
You would also need the
dip stick
dip stick tube
rear sump pick up tube
Main bolt with the stud for the pick up tube
Might try the boat pan or one from an industrial engine
I also don’t think that is a rear sump pan...
FORM-A-FUNNEL comes in handy...
erikhillard
That looks like a great idea! Thanks for the Form A Funnel tip
https://www.amazon.com/FORM-FUNNEL-Flex ... 017MTFIYE/
Best,
Erik H
1968 F100 Ranger
California
tnlprt
Post by tnlprt »
The pan pictured is actually a car front sump pan
sargentrs
Post by sargentrs »
You could just install a drain plug valve and hose. https://fordification.com/forum/viewtopic.php?t=65249
