Need C9TA-3590-E pitman arm!
Ohiotinkerer
Post by Ohiotinkerer »
WTB pitman arm casting #C9TA-3590-E..........getting ready to replace drag link and ends and want to replace the one I have with the correct one while I have everything apart!
"Life is a garden - dig it"........... :thup:
1997 Honda CBR 900RR
hfdco4
Re: Need C9TA-3590-E pitman arm!
Post by hfdco4 »
I have a pitman arm but not that exact number. I think its the same but older.
:fr: FE390PC
1970 F250 4x4
2016 F150 4x4 2.7 ECO
Gone 1988, 1989 & 1991 Broncs
hfdco4
Post by hfdco4 »
OK after some searching the Pitman Arm #C9TA-3590-E is for Power Steering, The one I have #C7TA-3590-N is for Manual Steering. I found that by looking here: https://fordification.com/partnos/steering-column.htm
:fr: FE390PC
1970 F250 4x4
Ohiotinkerer
I just appreciate you taking a look - these things must be like hens teeth!...... :hmm:
