1971 F100 Crown Vic swap w/Supercharged LS swap
- Manny
Re: 1971 F100 Crown Vic swap w/ Turbo LS
Congrats on getting up and running snot rocket. Fuel economy might be surprising if you can keep your foot off it!!
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
Last drive of the season. Goes under the knife this winter. BIG plans!
- Manny
Re: 1971 F100 Crown Vic swap w/Supercharged LS swap
Curious to see.
What are your plans? I think it looks great now!
Kyle
Kyle
Sneak peek with my invisible tires..
Was out measuring to figure out tire size. Looks like 305 in front and 335 in the rear. 19x9.5 front wheels, 19x10.5 in the back. Suspension and brakes this winter too.
- Manny
Sounds good keep us posted with your winter progress!
Tires came in. Decided on 305/35ZR19 Nittos.
That looks mean! Great choice in tires.
Kyle
Kyle
- cdnwillyg
Wow nice combo, great ride height as well.
1968 Mercury M250 Camper Special
FE-390,570CFM 4bbl, C6 Automatic, PS, PB front disk.
Stony Plain, Alberta, Canada
:drive:Willy
:drive:Willy
Sits really good. What year exploder rear? What backspacing on the front and rear. What plans do you have for the suspension.
- 67mann
The wheels are 19x9.5 +35 on the front, 19x10.5 +20 on the rear. To run them with the explorer rear you need 2.5-3" of spacer. I'm switching to a crown vic rear which should be perfect with this offset. Hopefully doing a 4 link in the rear and coil overs front and rear. That's if oil prices go up.67 bump wrote:Sits really good. What year exploder rear? What backspacing on the front and rear. What plans do you have for the suspension.
Happening for sure are new gauges and cruise control via dakota digital and adding a/c. Already have a power window kit sitting there ready to install too.
Put one of the fronts together. Tons of room with a 275/35ZR19. My truck also doubles as a drying rack for my kids hockey gear. Lol
Snot Rocket wrote:The wheels are 19x9.5 +35 on the front, 19x10.5 +20 on the rear. To run them with the explorer rear you need 2.5-3" of spacer. I'm switching to a crown vic rear which should be perfect with this offset. Hopefully doing a 4 link in the rear and coil overs front and rear. That's if oil prices go up.67 bump wrote:Sits really good. What year exploder rear? What backspacing on the front and rear. What plans do you have for the suspension.![]()
What year of crown vic rear are you going to use? widths changed I think in 03 when they went to the aluminum cross member in the front. I am loving your project!! I had to go with new leaf springs in the rear of my truck due to the project draining my account. But I hope to make a change to a 3 or 4 link setup. for now I may get the Caltrac bars to eliminate wheel hop. But then I think deal with it and put the money of the caltracs towards a better setup like a 3 or 4 link. Main thing is I want to get back to some autocrossing some but mostly street driving.
Barry
