Frame Width
- bumt72
Frame Width
A while back someone posted the frame widths of the various for trucks, up to 79 I believe. Could you post it again. I searched the old site but couldn't find it.
re: Frame Width
I think the thread you're looking for in here at the old forums. Here's what you need, courtesy of 68F250:
- '67-'72 2WD/4WD all narrow (don't know how far back that goes, 34" wide was an SAE standard for all trucks back then)
- '73-'79 all 2WD narrow front, wide rear
- '73-'79 F100 4WD narrow front, wide rear
- '73-'77.5 F250 4WD all narrow
- '77.5-'79 F250 4WD narrow front, wide rear
- bumt72
re: Frame Width
Thanks, i've been researching the frame swap vs subframing vs front end grafting and trying to collect information on fseries trucks, wheel base frame widths etc. Coul you and everyone else take a look at this link and let me know if you know that anything is incorrect or can fill in some of the holes?
Thanks
Kep
http://www.dock.net/kep/bumt/fseries_frame.htm
Thanks
Kep
re: Frame Width
I compared your numbers with the ones listed in the 'Standard Catalog of Ford Trucks 1905-2002' and found quite a few wheelbase figures that don't agree with your info, so I got them all for you here. For example, '74 and '75 were the only years of that era with a shortbox Crewcab:
1953-1955
F100 1/2-ton - 110" WB
F250 3/4-ton - 118" WB
F350 3/4-ton - 130" WB
(F350s were still classified as 3/4 ton trucks up through '55.)
1956-1960
F100 1/2-ton SWB - 110" WB
F100 1/2-ton LWB - 118" WB
F350 1-ton - 130" WB
1961-1963
F100 1/2-ton SWB - 114"
F100 1/2-ton LWB - 122"
F250 3/4-ton - 122"
F350 1-ton - 132"
1964
F100 1/2-ton LWB - 128"
F250 3/4-ton - 128"
F350 1-ton - 132"
1965-1966
F100 1/2-ton SWB - 115"
F100 1/2-ton LWB - 129"
F250 3/4-ton - 129"
F250 3/4-ton CrewCab - 147"
F350 1-ton - 132"
F350 1-ton CrewCab - 152"
1967-1968
F100 1/2-ton LWB - 131"
F250 3/4-ton - 129"
F350 1-ton - 132"
1969-1970
F250 3/4-ton - 131"
F350 1-ton - 135"
F350 1-ton CrewCab - 159.5"
1971
F250 3/4-ton - 131"
F250 3/4-ton CrewCab - 159"
F350 1-ton - 135"
1972
F250 3/4-ton - 131"
F350 1-ton - 135"
F350 1-ton CrewCab - 159"
1973
F100 1/2-ton SWB - 117"
F100 1/2-ton LWB - 133"
F250 3/4-ton - 133"
F250 3/4-ton CrewCab - 161"
F350 1-ton - 137"
F350 1-ton CrewCab - 165.5"
1974
F100 1/2-ton Supercab LWB 6-ft bed - 140"
F100 1/2-ton Supercab LWB 8-ft. bed - 155"
F250 3/4-ton - 133"
F250 3/4-ton Supercab - 140"
F250 3/4-ton CrewCab - 155"
F350 1-ton - 137"
F350 1-ton Supercab - 140"
F350 1-ton Platform/Stake - 161"
F350 1-ton CrewCab - 166.5"
1975
F100 1/2-ton Supercab 6-ft bed - 140"
F100 1/2-ton Supercab 8-ft. bed - 155"
F150 1/2-ton - 133"
F250 3/4-ton - 133"
F350 1-ton - 137"
F350 1-ton Supercab - 155"
1976
F100 1/2-ton Supercab - 155"
F150 1/2-ton - 133"
F250 3/4-ton - 133"
F350 1-ton - 137"
1977
F150 1/2-ton - 133"
F150 Supercab - 155"
F250 3/4-ton - 133"
F350 1-ton - 137"
1978-1979
F150 1/2-ton - 133"
F250 3/4-ton - 133"
F250 3/4-ton Supercab - 155"
F250 3/4-ton Crewcab - 155"
F350 1-ton - 137"
Now, I WILL say that I've found other discrepancies in this book, so don't take every bit of this as gospel.
1953-1955
1956-1960
1961-1963
F250 3/4-ton - 122"
F350 1-ton - 132"
1964
F250 3/4-ton - 128"
F350 1-ton - 132"
1965-1966
F250 3/4-ton - 129"
F350 1-ton - 132"
1967-1968
F250 3/4-ton - 129"
F350 1-ton - 132"
1969-1970
F250 3/4-ton - 131"
F350 1-ton - 135"
1971
F250 3/4-ton - 131"
F350 1-ton - 135"
1972
F250 3/4-ton - 131"
F350 1-ton - 135"
1973
F250 3/4-ton - 133"
F350 1-ton - 137"
1974
F250 3/4-ton - 133"
F350 1-ton - 137"
1975
F150 1/2-ton - 133"
F250 3/4-ton - 133"
F350 1-ton - 137"
1976
F150 1/2-ton - 133"
F250 3/4-ton - 133"
F350 1-ton - 137"
1977
F150 1/2-ton - 133"
F250 3/4-ton - 133"
F350 1-ton - 137"
1978-1979
F150 1/2-ton - 133"
F250 3/4-ton - 133"
F350 1-ton - 137"
- bumt72
re: Frame Width
Thanks Keith, somehow knew youd have it, grin. The one I had a big question on is the 73+ SWB trucks. I was getting numbers between 116 and 117. I found a 77 stepside that I was considering picking up for a frame swap for the 61 but a 3 inch difference??? Hmmm that may not look right. And the quest goes on.
- zakt
re: Frame Width
Keith,
Are you sure about the 67' F350 crewcab? Heres what I found elsewhere?
1972 Ford F350 crewcab
