cab, bed, rear axle
cab, bed, rear axle
I have a cab from a 1969 F250. there is very little rust.
None in the floors or drip rail.
some in the lower cab corner underneath on right side. cant see unless you under the truck, other that that, it is solid as they come.
it has a cracked windshield with the trim, and a slider back window still on it.
$500 firm, no paperwork comes with this. No other parts available at this time.
I can help load it with a tractor.
Rear axle from a 69 Camper Special. This has the larger drum brakes and 3:54 gears. (Axle code 37, Dana 60) $250
Core support from a '72 good shape $50
'69 bed, no rust but left side and tailgate are damaged. $100
1968 Highboy
1976 Highboy
1969 F250 Camper Special
1941 Dodge Power Wagon
1930 Model A Coupe (Hotrod)
1962 Fairlane 500 Sports Coupe
VW Sandrails
Honda ATC's
36' Diesel Pusher for roughing it.
1976 Highboy
VW Sandrails
Honda ATC's
- colnago
Re: cab, bed, rear axle
What is included with the rear axle? Hubs, drums, etc. Any photos?
Joseph
Joseph
I am in Ramona, Ca. about half hr east of Escondido.
the rear axle is complete, came off a running and driving truck. a return spring or something is loose inside one of the drums, it was easier at the time to just replace the whole thing with another one I had.
Pics are here:
http://sandiego.craigslist.org/nsd/pts/5427727826.html
Thanks.
Pics are here:
Thanks.
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
1976 Highboy
VW Sandrails
Honda ATC's
still have all this.
Cab $300
also, gas tank, $45
front fenders $45 each good shape.
Let me know. can take to work in Chino (not the cab, too big).
Cab $300
also, gas tank, $45
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
1976 Highboy
VW Sandrails
Honda ATC's
- Jacksdad
I saw your post on Craigslist back when you first advertised it - I just wish I'd known about the cab before I started welding mine up. I'm in San Diego and it would have saved me a bunch of time
I know a couple of guys locally with bumps - I'll put the word out for you.
1971 DRW F350 cab and chassis with an Open Road motorhome conversion, Dana 70, 352 (originally 390)/C6, PS, power front discs, and 159" w/b.
Do you still have the core support?
C7TZ wrote:Do you still have the core support?
Yes, I do.
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
1976 Highboy
VW Sandrails
Honda ATC's
Rear end has been traded off for shiny stuff.
top of cab is gone, anyone need patch panels? floor is good.
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
1976 Highboy
VW Sandrails
Honda ATC's
Are rockers in good condition? How much shipped to 19438.
Any inner cab corners
Here is some pics of the cab parts.
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
1976 Highboy
VW Sandrails
Honda ATC's
More.
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
1976 Highboy
VW Sandrails
Honda ATC's
yup.
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
1976 Highboy
VW Sandrails
Honda ATC's
