and one of the things in the back of my head was to try this swap once I got the body out of the way.
So now that’s done I spent last week mocking up engine mounts for my 460 (I got out of a 77 Lincoln) so it could mount onto the 2002 frame.
I cut out the cross member from the Lincoln Mark V and grafted it onto the truck cross member and the 460 dropped right in. The 02’s frame has two trany mounting positions and the back one was a perfect fit.
With that done I moved my truck into the shop and took it apart.
Pushed out the old frame and moved the 02 in.
Did a test fit with just the bed first, pulled it back off and then put the cab up on it.
I couldn’t believe it but the front cab mounts were an exactly perfect fit. As you can see in the pic’s the bolts dropped right in and are straight.
The bed is about 3" to high so I will need to fugure out how to make it line up but It looks like I should have room to lower it by notching the bed rails.
Now the 02 was an extended cab and I have always wanted a short bed bump so I will have to cut down the frame and then the bed but I planed on doing that to the old frame before I got the 02 so no big deal. 23-1/2” will need to be cut out and that will bring the rear cab mounts up to the correct position. The 02 has disc brakes all the way around and a very nice ride so this should be a great upgrade for my old 72.
