Keep in mind guys its not going into a drag truck. It needs to be streetable. But streetable to me can be something other than stock.
Its going to be bolted to the factory 303 3 speed & im still going to row the gears with the clolum shifter. 9" rear with 3:25's. The truck will be driven less than 500 miles a year, just on the weekends & to cruise nights & shows & things of that nature.
Here is what I have in mind. Please tell me your thoughts & if you have a reccomendation, I want to hear about it.
1971 302 V8
start with a good rebuild, with quality components & bore if needed.
Go through the heads & make sure eveything is ok.
Edlebrock preformer (or similar) intake. Nothing too drastic, no single plains...
Eddy 4bbl carb CFM??
268'ish?? cam with compatable valve train. I would love to run a lumpy stick just for the sound, since i dont drive the truck all that much. But I dont want to compromise streetability & I cant spend a pantload on the 40 year old iron heads.
headers & good exhaust
electronic ignition, good wires ect.
I think that would perk the old man up alittle & turn heads when I pull into a show as well.
What do you guys think???????
