o/t duraspark
flatblack
o/t duraspark
Post by flatblack »
does anyone know the duraspark system?? ive head different people talk about it, mainly the modules how there different colors ie blue. heres my dilemna: im swapping a small block into a 84 mustang, it had a duraspark ignition system in it for the 3.8L, i have a duraspark distributor for the 302 but it didnt come with a module. can i just plug and play or do i have to find the right module? then if i do that how much do i need to know about wiring to install it properly? i really dont want to spend a whole lot of money since christmas is coming up, i just want it to move and maybe take a trip in the next month with it. if money wasnt a problem i would probably buy a msd system. but basically i just want it to run and be reliable until i can gather up some more money. ive already put lots in rebuilding the 302 so its getting pretty tight.
Nitrous is like a hot girl with std's... you know you want to hit it but your afraid of the consequences
fitzwell
Re: o/t duraspark
Post by fitzwell »
Modules all basically interchange. Easiest to find id the "Blue Grommet" unit...Napa TP40. There is a "california module" and a matching coil, which is supposed to have a higher output,...never verified that.
flatblack
Re: o/t duraspark
Post by flatblack »
so the v6 module will work for the v8 distributor?
Hawkrod
Re: o/t duraspark
Post by Hawkrod »
Modules are the same for 4 6 or 8 cylinder engines, the module does not care how many cylinders are in an engine, they just make the coil fire every time the distributor pickup send a signal. All that matters is that you have the correct module for the wiring in the car. Distributors all have the same plugs. As far as an 84 is concerned they only used one module by that time. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
Hawkrod
Re: o/t duraspark
Post by Hawkrod »
fitzwell wrote:Modules all basically interchange. Easiest to find id the "Blue Grommet" unit...Napa TP40. There is a "california module" and a matching coil, which is supposed to have a higher output,...never verified that.
I would qualify that statement. All modules do not "basically" interchange although most do. There are several that do not interchange at all as they have a different connector and wiring. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
fitzwell
Re: o/t duraspark
Post by fitzwell »
I was referring to the Durespark II modules only.
OldRedFord
Re: o/t duraspark
Post by OldRedFord »
Where can I find out the differences on the different color modules?
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
Hawkrod
Re: o/t duraspark
Post by Hawkrod »
Some reading: http://www.geocities.com/cantwait_forvi ... gnmod.html. This only covers a few. There are red yellow white and blue strain reliefs that I know of but there may be more. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
fitzwell
Re: o/t duraspark
Post by fitzwell »
OldRedFord wrote:Where can I find out the differences on the different color modules?
sure there is a more technical referance, (circuits affected, etc) but the Napa illustrated Ignition manual should have the basic information. I'm looking for my OLD motorcraft catalog as we speak.
willowbilly3
Re: o/t duraspark
Post by willowbilly3 »
Run the blue, don't confuse yourself with too much info. Most of the other colors were early versions, like the black and green and they might have been superseded by the blue later on, can't remember for sure. Then I think one (yellow?) might have been designed for multiple applications. I had a new one laying around for years and it had 3 pigtails.
Lots of the guys on Fordsix recommend using a chevy module but for the life of me I don't know why.
I prefer to get all my blue grommet modules from junk cars, get the OEM part because a used on of those is better than any aftermarket one is new.
BobbyFord
Re: o/t duraspark
Post by BobbyFord »
You can also easily run an MSD box...
willowbilly3
Re: o/t duraspark
BobbyFord wrote:You can also easily run an MSD box...
Maybe you could elaborate a little, what is required? Is it a plug and play?
aramil
Re: o/t duraspark
Post by aramil »
:yt:
72, f-100 ranger xlt, 360-c6, 2wd 84k miles.
77, ford f-150 custom 4x4, 400m-c6 SOLD
"the existence of flamethrowers is proof that someone, somewhere, sid to himself, "i want to set those people over there on fire, but i dont feel like walking over there to do it"
BobbyFord
Re: o/t duraspark
Post by BobbyFord »
If you go on the MSD website there are wiring diagrams for just about every system out there. I think it's under the "Tech" tab. I'll see if I can post a schematic, I've got one somewhere...
*Edit*
Page 18...
http://www.msdignition.com/uploadedFile ... ctions.pdf
aramil
Re: o/t duraspark
Post by aramil »
*bookmarked*
that seems like it would probly be the better more expensive option to the stock duraspark setup. but do you still need the duraspark distributer?
