For the those of you that swapped a 460 into your bump, what power steering pump and bracket did you use?
I was looking at the L&L website and according to them I need a adapter or something.
p/s pump bracket
- OldRedFord
p/s pump bracket
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
- OldRedFord
re: p/s pump bracket
The L and L kits are designed to 'adapt' existing parts to work. That is, for example you can use their adapter mounts with your existing FE engine stands, to save you from having to find the proper 460 engine stands.
In this case, if you've got (for example) a 360 with power steering and want to 'adapt' the existing pump to bolt to the 460, you can use their adapter. However, virtually all 460 engines came with power steering...finding the correct bracket shouldn't be any problem. If you can't find the correct bracket, and/or you've got an extra $125 burning a hole in your pocket, you can get their bracket.
- OldRedFord
- OldRedFord
