69 twotones Ranger project
- 69twotone
Well guys I am excited I am finally getting to post my own project thread. This last weekend my wife and I journeyed down to Keystone Iowa to pick up a 68 cab from forum member Snake. The trip took just shy of 11 hours and I made it there and back in my 69. The gas mileage was not the greatest and between the trailer and gas spent close to 240.00 to get there back. The 69 ran great though and did not give me any problems. It barely burned any oil. The cab is in my garage now and ready to start prepping for paint. I have to pull some dents out and take a wire brush to some of the areas with surface rust. Which I will be starting on in about a week. I am having a bed delivered next week off of a 67 and will post pics of it then.
picture of cab on trailer outside of Des Moines
http://s237.photobucket.com/albums/ff10 ... ipback.jpg
Another picture of cab on trailer
http://s237.photobucket.com/albums/ff10 ... stview.jpg
Sunset in Iowa
http://s237.photobucket.com/albums/ff10 ... sunset.jpg
Cab at home in my garage
http://s237.photobucket.com/albums/ff10 ... garage.jpg
One last picture of cab in garage
http://s237.photobucket.com/albums/ff10 ... kofcab.jpg
I will post these as links for now sorry, I tired to get them to post as pictures with the img command but maybe photobucket does not allow hotlinking.
Sunset in Iowa
69 f100 Custom cab Two tone maroon and white
Looking for a steering wheel with the horn ring, maroon or any color. PM me
- seattle67
re: 69 twotones Ranger project
Nice, that cab looks to be in great shape!
Dan
"I plan to start procastinating immediately"
- rjewkes
looked through your picture album, on the black 69 that looks to be in a junkyard, any chance its still there?
wondering as i would like to get a spot light or two like the one on it.
fuelly.com
fuelly.com
Congrats on the cab. I'm sure you enjoyed driving your 69 to make the trip. Will look forward to your updates. John
- rjewkes
maybe
fuelly.com
fuelly.com
- 69twotone
re: 69 twotones Ranger project updated 5/5/08
Well it ahs been a couple of weeks and I have been quite busy pulling dents out of the cab and the bed. I am pretty satisfied so far for my first attempt at body work
This is the first dent I tried to pull out with a stud hammer after practicing on a junk panel.
Still dont think I practiced enough the dent is out but you can see the holes the stud welder nails left becuase I pulled to hard.
Here is another in the front of the cab
after using the stud welder a couple of small holesfrom the nails
Left wheel well before using a body hammer
after using a body hammer and about 2 hours work it is almost perfect but you can still feel and see a few of the small imperfections. I tried using a wire wheel on the back so that I could see where the metal was raised and target those areas. has helped some. Does anyone know of a way otto work out the small imperfections. The body hammers if used to much seem to start pushing the dent out.
The front side of the bed has come out the best so far
before
after
My son who loves helping me
This is the one part I am not sure what to do with. I will have to get a closer pic. RIght below the passenger tailight the metal is dented and is spilt from the tailighton around the corner. I will probably have to have some one weld it since I do not know how.
So far I am pretty happy with the results I can't expect myself to be perfect still a long way to go though.
before
after
- rjewkes
was this the pic?
the second tag has to read [/img].
fuelly.com
fuelly.com
- 69twotone
Thanks Rjewkes, have been trying to do pos the actual pics forever. I think I got it now wil try some more
- rjewkes
No problem , Your getting it. looking good. anytime you feel like a roadtrip to practice body work...
fuelly.com
fuelly.com
- snake
Looks good twotone. Be sure to keep us posted.
Hopefully I'll be able to get one of my bump projects in my shop and start actually working on it once in awhile.......
- 69twotone
Thanks Snake,
Which one are you thinking about starting on?
- snake
I won't go into all the reasons and sequencing but from a logistical standpoint I need to work on the F-250 'Shop Truck' first.
Then when that is done I can start working on the half ton 'Hot Rod' project.
One question for you: How are you removing the studs after you have pulled the dents out?? I'm wondering if you are 'bending' them off and that is why you are getting the holes (the sheet metal of the body is weaker than the stud so the body tears rather than the stud coming off...). Try cutting the studs off - either with a cut-off wheel in a grinder or even with a hack saw. You will then have to grind the little bit of stud left on but you won't have the holes then...... Just a thought!!
- 69twotone
My intention is to cut them off but they seem to be popping off while I am using the slide hammer. I don't know if I am not weldong long enough but the directions say about a second so I generally count one one thousand and let go. Then it seems like about half way through pulling the dent I end up popping the stud off with the 2 lb slide hammer I am using. I have been trying to pull easier and have been met with better results and actually left one on the truck. But I am still breaking more off than I am leaving on.
I started on the bed and they seem to pop off even easier. The directions state that if they are not welding right to be sure the metal is extra clean. Have tried that and they still seem to be popping off after a couple pulls on the slide hammer. Maybe I need to practice on a spare fender some more.
- rjewkes
did you get the stud gun from harbor feight?
was it extremely expensive?
fuelly.com
fuelly.com
- snake
I wouldn't worry about your method of welding the studs on or at least that you aren't holding the gun long enough - since they broke off leaving a hole, that indicates the weld was stronger than the metal you welded the stud to. If anything, you might have held it too long which can cause heat stress right next to the weld causing a weak point.
Another thing you might consider is welding more studs on so that you don't pull as many times on each one. (does that make sense?) The ones that broke off could very well have been welded on properly but no matter how well its welded on, it will only take so many 'pulls'. Kinda like bending the paper clip - you can bend it back and forth a few times but it will reach a limit when it will break.
Practicing on a loose, unmounted fender will not work very well or give accurate results simply because the entire fender will move too much - got any dents on your truck??? got a hammer to make some??
Anyway, keep plugging away at it...............
