steering stabilizers how would this go on?
- rjewkes
I've got the new catalog(and the part was in te old one too) But with the distance between the I-beams and the steering linkage how would it work and where would i bolt it.
fuelly.com
fuelly.com
- heep70
re: steering stabilizers how would this go on?
Probably have to run it off the frame.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- rjewkes
ok cool.
fuelly.com
fuelly.com
IIRC, for installation on a 2WD pickup there's an L-bracket that gets clamped to the side of the I-beam with U-bolts, and the stablizer then extends from this L-bracket over to the steering linkage.
- boots
so you can get steering stabilizers for a old 2wd ford? can i have a link?
Ethan
67 f100 - 4"lift - cut fenders - 36 TSL's
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
http://www.fordification.com/forum/view ... 835#136835
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
Here's a couple links for ya:
http://www.hellcreeksuspensions.com/ste ... r_page.htm
http://www.jegs.com/cgi-bin/ncommerce3/ ... rmenbr=361
- rjewkes
and these u-bolts the don't interfere with the suspension?
fuelly.com
fuelly.com
- boots
thanks
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
those were a stock item, no? my 67 f250 CS has one......
Recognition is the key to discovery
- rjewkes
Perhaps on the camper and scamper specials but not on the 100s
fuelly.com
fuelly.com
Don't think so...As far as I know, none came with
steering stab's from ford. All are aftermarket...
Or at least as far as I've seen...
MK
MK
1968 F-250 / 300 six / T-18
Dana 60 - 4.10 Limited Slip
- rjewkes
Thanks that what i thought.
fuelly.com
fuelly.com
- GT-Racer
My parts truck has one and its a F100 2wd. Its attached to the frame and then to the steering linkage. Not the I beam.
Heres some pics hope it helps.
'67 F100 2wd shortbed - Beginning restoration.
351w, 5-speed, 3:70 gears (someday)
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....
- boots
gt-racer, did you have to custom fit that in to bolt it on? Are steering stabilizers only for power steering trucks?
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- heep70
Manual steering more then power steering
Greg
