Time to put "Project Blue Beast" up.
re: Time to put "Project Blue Beast" up.
Experienced my first setback today. After getting the input shaft and everything aligned, pins set in place and started threading bolts than started to torque it down and CRACK. Bellhousing just said good bye. So now in the process is deciding on a new tranny...
1968 Ford F100 2WD 360
Ford 1 & 2 BBL and Carter 1 & 2 BBL Carb Rebuilder Extraordinare!
Thought I might share this with you. That air cleaner might hurt your performance. I had one like that on my 68 mustang with a hipo 390. We had it on the dyno making 348 rwhp. Switch it with a 14" round with 4" element that the dyno shop had laying around and got 367 rwhp. K&N of the same size made 365 rwhp. The dyno teck claimed that style of air cleaner caused turbulence above the carb. That was on a holly 750 dp so it may be different with that style of carb.
RTG_Racing. I will give that some definite consideration.
Some big progress being made for me the last three days. Got some more stuff to finish up the motor. New oil pickup, ARP oil pan bolt set, a new tranny jack, new tranny, complete exhaust system from Hooker with some series 50 flows, and a set of flanges to go from the header to the exhaust system.
After putting on the new Milodon pan, pickup, and ARP bolt set, I got started on finishing up the old paint/grime removal from the engine bay to prep it for paint and hopefully within the next three weeks it will be running and it may not have a paintjob on the outside but it'll be runnin good on the inside. Down the road it will have a complete set of bodywork done which isn't much seeing it has no dents/dings. There is some small rust spots but nothing serious. I am stoked, finally gonna have a running truck.
For those of you who like visual stimulation. Here are some more photos.
Sorry about the incredibly slow updates. Time and cash has been tight so I have been trying to do what I can with what I got. Like the post above says. Should be running in three weeks or so.
Well made some serious progress, engine is mounted up, just have to bolt up the tranny and finish up the wiring in the engine bay.
- 69F110
Air Compressor + Cheapo Kragen's Special Paint Gun. Actually doesn't work half bad. Used their ready to go primer and jet black paint. All you have to do is shake the can, and than strain it, pour it into the gun and spray.
- 71 LONG BED
Sure is purdy!!
John Member #1549
71 F100 Sport Custom__________1967 F350 Gone, but not forgotten
Well. Wiring is done. Works. Waiting for my third radiator now. The original was toasted, second one (brand new) had a foot put through it, and the third one(again brand new) looked like someone had stabbed it with a large screwdriver. Once the radiator is in and filled and doesn't leak I am gonna drop in the new battery, prime the oil pump and fuel pump, and turn it over.
- basketcase0302
Ares68,
That is one fine motor!
Basketcase
Basketcase
- cghstrojan08
Looks awesome.
ROBERT
Member #1076
1968 F100 SWB 360
1969 F100 LWB 360 "Ol' Blue" - Sold
1976 F350 Trailer Special, Extended Wheel base, 460
http://s9.photobucket.com/albums/a75/cg ... ld%20Blue/
Member #1076
1968 F100 SWB 360
- SebringSixSpeed
Re: re: Time to put "Project Blue Beast" up.
RTG_RACING wrote:Thought I might share this with you. That air cleaner might hurt your performance. I had one like that on my 68 mustang with a hipo 390. We had it on the dyno making 348 rwhp. Switch it with a 14" round with 4" element that the dyno shop had laying around and got 367 rwhp. K&N of the same size made 365 rwhp. The dyno teck claimed that style of air cleaner caused turbulence above the carb. That was on a holly 750 dp so it may be different with that style of carb.
