proportioning valve bracket
- customcrewcab
made a proportioning valve bracket today. it bolts to the hydroboost and mounts under it. heres acouple of pics. one of the bracket and one mounted in the truck.
- 69bumptruck
re: proportioning valve bracket
Showoff.
Just joking. That's some nice work. Very clean.
BTW, that's one sick looking truck! (In a good way)
I agree! That's a very slick-looking setup. Nice job!
- customcrewcab
i like it
. dang they want 1.40 a piece for stainless 3/8 1 1/2 bolts. they look nice but i am starting to be shock on how much evething is marked up. i guess i can start routing my lines then maybe i can mark off the brake system off my list
