And that is about all I know about brakes.
So, i tried to bleed the rear brakes, but no fluid came out.
Fluid comes out of the front ones.
The truck will come to a stop by the brakes if it is slowly moving forward, but not backwards.
Pressure at the pedal is very very slight.
It appears to be a stock 67 system, all drums.
I took this to be a problem with the master cylinder or the booster, so I took them out to see if I could see anything. The pictures are attached.
What I am wondering is if anyone has an idea of what the problem is, and then hopefully a solution
