Anyway, I've sent numerous e-mails to the seller asking him if the truck this was removed from was equipped with cruise control and haven't gotten a reply yet (he obviously isn't into customer service!). There was no steering wheel so I have defer to those of you who have messed with these before. I'm guess that the two little copper electrical contacts sticking up in the picture below is for the cruise control buttons on the wheel. Is this a correct assumption?
Also, the hole for the shift lever pin in the shift collar is worn out, meaning I'll have to replace the collar. I don't suppose a regular column from the same year could be used as a donor or does a tilt column use it's own shifter collar?
